Machining help?
Old 05-04-2007, 06:19 PM
JimboGT01
JimboGT01's Avatar
Default Machining help?
Im just wondering, When you take the block to the machine shop to have them bore it .020 what esle do they do? Like would they normally clean/machine the decks where the heads sit, maybe run it through a cleaning machine? and are boring and honing two different things?
jimbo
JimboGT01 is offline
Old 05-04-2007, 07:35 PM
Triisomy21
Triisomy21's Avatar
Default RE: Machining help?
I'm giving you a link to an engine shop. At the top of this particular page are a bunch of pictures of the machines and what they do. Below that is a little bit of info on what it takes to prep a block for assembly. Although it doesn't exactly tell you what each process does, I'm sure if you emailed them or googled a few terms you'd find what you're looking for. It's cool sh*t!!
http://www.ahmperformance.com/theengineshop.html
Triisomy21 is offline
Old 05-04-2007, 07:39 PM
99 GT vert
99 GT vert's Avatar
im not sure what all they do at the shop when they bore it out but there is a diff between borering and honing boreing is done a mill or lathe with a boreing bar and honing is done whith a hone on a honing machine and will not take as much off the block im not real up on honing but i have bored before ( im am going to school to become a tool and die maker and my dad owns a tool shop)
99 GT vert is offline
Old 05-04-2007, 10:17 PM
JimboGT01
JimboGT01's Avatar
thats good to know.
Old 05-04-2007, 11:08 PM
Triisomy21
Triisomy21's Avatar
ORIGINAL: 99 GT vert
man i couldn't understand a single thing you just said.
Old 05-04-2007, 11:31 PM
97targa
97targa's Avatar
They will first Hot Tank the block which dissolves the grime and cleans it up. Then they Magnaflux the blocks which is used to check for cracks etc. They will Deck the block next which strightens out the head surface for any minor imperfections(there are specs on limits to this with Mod blocks) Then they will bore it out to your specs this being .020 They hone the cylinders after the bore. This will help the rings seat properly. You can tell a freshly honed block because it will have cross hatches on the walls (45 degree scores crossing each other) You will get new freeze plugs and then it gets crated up with a tag.. Hope this helps
97targa is offline
jwog666
12-27-2021 08:09 PM
lovesilver
Members Mustangs
05-09-2019 09:18 PM
flash_xx
10-16-2015 07:23 AM
dudeguy421
09-24-2015 11:16 AM
fastbackford351
09-12-2015 09:42 AM
Quick Reply: Machining help?
