Passenger Door Problem
Old 05-04-2007, 08:20 PM
ufautoguy
ufautoguy's Avatar
Default Passenger Door Problem
Has anyone else had this problem. I recently bought my 2000 GT, and have noticed that my passenger door doesn't close quite right. I have had the latch adjusted, and hasn't fixed the problem. It shuts and latches, but there is still a larger gap than there should be and window doesn't match up correctly, where if I press on the window with the door shut it goes in the weather stipping, but otherwise is on the outside. Any help?
ufautoguy is offline
Old 05-04-2007, 08:27 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Default RE: Passenger Door Problem
ORIGINAL: ufautoguy
Get a carfax see if the car has been t-boned. You will need to take it to a body shop and they can do a fender/door alignment that should fix the prob. Probably charge you an hour or two of labor.
Derf00 is offline
Old 05-04-2007, 08:29 PM
ufautoguy
ufautoguy's Avatar
I did a carfax...no problems reported, and I bought it from someone I trust.
Old 05-04-2007, 09:17 PM
StealthGT2V
StealthGT2V's Avatar
ORIGINAL: ufautoguy
you can never beso sure...
StealthGT2V is offline
Old 05-04-2007, 10:18 PM
ufautoguy
ufautoguy's Avatar
I actually work for AutoTrader.com, so I definately trust where I got it from. I was just wondering if anyone had this problem before, and if there was an easy fix.
Old 05-04-2007, 10:22 PM
DEALBRk
DEALBRk's Avatar
My friends 02 does the same thing. Thats why on the new mustangs the window auto. roles down a lil when you open and close it.
DEALBRk is offline
mustangchef
09-04-2015 08:08 PM
cbird1177711
09-03-2015 08:43 PM
amandahchase
09-03-2015 10:09 AM
cbird1177711
09-02-2015 08:51 PM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: Passenger Door Problem
