shift points
shift points
I have a auto 96 mustang gt. I was wonder if I raise my shift points all the way would it slow my car down from heat or does it cool it with higher pressure. its like a shift kit I also have 4:10 gears
RE: shift points
What do you mean by all the way? Raising your WOT shift points will keep you in the powerband longer, and you can get a much better ride with it. Running higher rpms will always make a engine run hotter, but the extra power you get because you stay in the powerband makes up for it. The shift points and shifting from factory are crap on auto transmissions.
RE: shift points
ORIGINAL: super96stang
jwog666
12-27-2021 08:09 PM
