Depressurising fuel system
Old 05-05-2007, 01:12 PM
Shelbyville
Shelbyville's Avatar
Default Depressurising fuel system
I want to replace my fuel filter, and I figure as long as I am depressurising the fuel system, replace the spark plugs too. I read that pulling the connector off the fuel pump relay switch in the trunk and then letting the car run dry is a way to depressurise. Is this the best way or is there something else I can do.? Also, has anyone had any problems with fuel leakage after popping off and back on the fuel rails?
Shelbyville is offline
Old 05-05-2007, 01:15 PM
sprostang
I ♥ Acer
sprostang's Avatar
Default RE: Depressurising fuel system
That way will work and you won`t need to pop off the fuel rails to change the plugs.
sprostang is offline
Old 05-05-2007, 01:18 PM
Shelbyville
How do you remove the coils without removing the rails? It appears at least from looking at it that the fuel rails are blocking the removal of these. Forgot to mention I have a 2002 GT.
Old 05-05-2007, 01:21 PM
sprostang
I ♥ Acer
sprostang's Avatar
Theres a 7mm screw holding down every coil pack. Remove the screw and turn and pull off the coil pack.
Old 05-05-2007, 01:40 PM
ShadowDrake
ShadowDrake's Avatar
ORIGINAL: Shelbyville
I had this same question, the coils just have a flexible rubber boot on the bottom, they can be pulled from under the fuel rail with no issues. You -may- have a schrader valve on the passenger side fuel rail... However Ford removed this at some point (mid 01 I think) because they figured we didn't need to depressurize the fuel system...? The reason for removing it is unknown to me but it's frustrating. Me? I can just remove the fuel line from my nitrous nozzle, put it into a cup, and open the solenoid
ShadowDrake is offline
Old 05-05-2007, 01:47 PM
HaV
HaV's Avatar
You can also remove the two screws holding the fuel rail down, and not disconnect them from the injectors if you need a little wiggle room. I have wider aftermarket fuel rails so that makes it easier to get a socket in there.
HaV is offline
Old 05-05-2007, 02:10 PM
StickShifty
StickShifty's Avatar
i have to say, changing plugs in the new edge is a breeze. just pop the coil pack off the plug and lift it up until it hits the fuel rail. then simply bend it out to you. takes about 10 seconds to pop it off. alot easier then you think.
StickShifty is offline
Old 05-05-2007, 02:21 PM
Sap
Sap's Avatar
Getting covered in Fuel is part of the fuel filter changing process. Its tradition.
Sap is offline
Old 05-05-2007, 03:53 PM
ZW99GT
ZW99GT's Avatar
ORIGINAL: Sap
Agreed. Just take off one of the lines to the pump, and catch what comes out.
ZW99GT is offline
Old 05-05-2007, 10:38 PM
M1ke
M1ke's Avatar
you dont need to depressurize the fuel system. just let it come out or clamp the hoses. also dont forget there's stil fuel in the filter and it can/will spill out
M1ke is offline
09-16-2015 07:53 PM
SteelerNation82
09-16-2015 07:11 AM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
09-10-2015 08:39 PM
uedlose
09-10-2015 03:30 PM
Quick Reply: Depressurising fuel system
