Has anyone ever put a 5.4 into a Fox body?
Old 05-05-2007, 06:14 PM
dasfonzie
dasfonzie's Avatar
Default Has anyone ever put a 5.4 into a Fox body?
Would a 5.4 Triton fit into a pre-edge fox body? I could see the hood being in the way, but about the engine bay?
dasfonzie is offline
Old 05-05-2007, 06:16 PM
lazyeye
lazyeye's Avatar
Default RE: Has anyone ever put a 5.4 into a Fox body?
impossible.
lazyeye is offline
Old 05-05-2007, 06:27 PM
dasfonzie
dasfonzie's Avatar
could you explain why?
Old 05-05-2007, 06:33 PM
ridedk4us
ridedk4us's Avatar
you can fit anything into anything with the moneybut it probably will need alot of fabricating
ridedk4us is offline
Old 05-05-2007, 07:08 PM
2000GT4.6
2000GT4.6's Avatar
ORIGINAL: lazyeye
impossible.
MM&FF has a lighting 5.4L in a fox, its far from impossible.
Its not that uncommon of a setup really. The only real problem they had was the hood, had to use a giant cowl and then they still had to cut parts out.
I think there are even a couple companys making k members for foxbodys now to fit in modulars.
2000GT4.6 is offline
Old 05-05-2007, 08:14 PM
JJ03MustangGT
JJ03MustangGT's Avatar
yea i heard you needed like a 5" cowl...and yea it can and has been done.
ORIGINAL: 2000GT4.6
ORIGINAL: lazyeye
impossible.
JJ03MustangGT is offline
Old 05-05-2007, 08:15 PM
JJ03MustangGT
you can get just about anything in a fox
ORIGINAL: lazyeye
impossible.
Old 05-05-2007, 08:18 PM
blueherd02gt
blueherd02gt's Avatar
Hmmm it's only a 330cu/in block, sure it's possible. A custom motor mount/ K-member will get you there....
blueherd02gt is offline
Old 05-05-2007, 08:22 PM
Colorado_Mustang
Colorado_Mustang's Avatar
It'll fit, but a 385 series big block would be easier and support a bit more power.
Colorado_Mustang is offline
Old 05-05-2007, 08:36 PM
ih8chevy
ih8chevy's Avatar
the dohc mod motors are wider than a boss 429. but its def possible epsecially wit todays tech. but my question is why? the pushrod motors are so much easier to mod and make fast than the ohc motors ford makes.
ih8chevy is offline
Quick Reply: Has anyone ever put a 5.4 into a Fox body?
