subframe connectors
subframe connectors
Hey guys I was thinking of getting some subframe connectors put on my 01 GT. What kind do you think would be the best to really help stiffin up the chassis? Another question, are control arms worth getting for a good suspension setup if you are really wanting to up your hp to about 500rwhp. If so, which ones, upper/lower rear, fronts? I really dont know anything about them. Thanks
RE: subframe connectors
MM subframes Yeah control arms would be worth it also. Any are better than the stock. anything from GRANATELLI, to Steeda, to MM all about the price you want to spend. Wouldnt worry about the front control arms unless you get a aftermarket k-member.
Steeda makes agood full lenght subframe connector. There are several to choose from, just do your research. If you plan on obtaining that kind of HP, you probably would be better off swapping the upper and lower c/a. Again, do your research and find out witch ones best suits you and your budget. www.50resto.com
jwog666
12-27-2021 08:09 PM
09-16-2015 07:53 PM
TfcCDR
09-14-2015 12:08 PM
09-01-2015 08:16 PM
