King Cobra Clutch
King Cobra Clutch
You guys with KingCobra clutches what has been your experience with them? Are you happy with them? Also when you buy the kit does it come with everything needed for the installation or is there anything else that is needed? Recommend changing anything else at the same time? This is the kit I'm thinking ofhttp://www.americanmuscle.com/kingcobra.html ,would there be anything else needed? Also what is the difference between the King Cobra and the Ford Racing Heavy Duty?
RE: King Cobra Clutch
get the best bearing install kit you can find, the american muscle one is great. it comes with a new throwout bearing and pilot bearing. do both of them. for the pilot bearing u will need a slide hammer to get the thing out. with any miles this will be hard so prepare to ahve to cut it out but dont damage the crank. besides that it comes with the aligning tool so use it. its not the BEST but itll get the job done, just make sure the clutch is centered correctly. youll want a new or refinished flywheel also. its really easy tho so good luck. that should be all you need, if u have anymore question just PM me.
i love the clutch though. it grabs like you wouldnt believe if all you have had it the OEM clutch(crap)
I have had no trouble with my KC clutch. I bought it from a local shop and had the guy put it in, but I think it comes with everything you need. Make sure the TOB is with it though. You should replace or have the flywheel resurfaced. I am not really sure about the difference in the two clutches though.
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
