High School Drags *RESULTS* *UPDATED & FINISHED*
RE: High School Drags *RESULTS*
ORIGINAL: BigTurbo6
Reaction time shouldnt effect for ET at all. And yes your 60 ft should be a around 2.1. Do you think it was bogging in 1st or spinning?? And just because I'm surious, what was your best 1/8th mile time?
i dont know but my 96 gt all stock except for slp lm1's ran a 14.9 with a bad .35 r/t at highschool nationals this wekend and u say ur car has a lot of mods something is wrong for it to run in the 15's with a lot of mods and my tires were at 35 all around
ORIGINAL: stangdriver2007
ORIGINAL: 2000GT4.6
If you get to low on a street tire it will bow up in the middle and cause problems. I dropped my buds LS1 tires down to around 25 PSI and it worked ALOT better than his stock 32 ish.
BTW, just because the tires say xxx max you don't want to put the max in, go with what it says in the manual/door sill.
Simply more proof (on top of the heaps already out there) that basic boltons do virtually nothing for a NPI car. With his 2.4 60's I would not expect to see anything but 15s.
This Wednesday when we go back to finish up I should be able to pull off a .0XX R/T and hope to get my 60ft. down to 2.0 or 2.1. And again why my times are so bad is because it was my first time.
Yeah as said above it is bracket racing so my R/T time does count against me.
My best 1/8 mile was 9.73
ORIGINAL: 97modifiedmustangGT
Thanks for being so positive. Not sure if you meant to come off as an *** butyou did to me.
now thats being an ***........................ just practice, get some sticky tires, get those 60 fts down, and you'll dip in the 14's........good luck
I hope you actually paid attention to what 200GT4.6 and I said and deflated your tires before you have a blowout on the highway.
Edit: By the way, I lied and said I had 245s for some reason... I only have 225s, either way, they are both 30 PSI according to the sticker
Edit 2: Here's the sticker, sorry it's blurry, I took it really quick earlier:
practice practice practice. the more you can get out to the track the better you will get my first time out at the track i couldnt get below a 14. somthing i forget but it wasnt good lol
