KB scam or not
Old 05-07-2007, 10:46 PM
Sonic_BlueProCharge
Sonic_BlueProCharge's Avatar
Default KB scam or not
EBAY
http://cgi.ebay.com/ebaymotors/FORD-...spagenameZWDVW
copy paste this link i found it on ebay
Sonic_BlueProCharge is offline
Old 05-07-2007, 11:29 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Default RE: Check this KB out
It's at $2650 with 4 days left, that's more than I'd pay for a "new, no box" = no warrantykit from Miami...
cliffyk is offline
Old 05-07-2007, 11:37 PM
ShadowDrake
ShadowDrake's Avatar
First: An intercooler (unless you are planning water/meth injection) is more of a SAFETY item, not a power item. If you want to preserve the life of your shortblock (I assume you do) you'll definitely want one. A benefit of it though, is that it will add power. Probably about 20% extra (add the 20% to what it's already adding... so if the blower adds 100 HP, add an intercooler and it'll be 120 hp).
The intercooler will make the install more complex (will need the intercooler pump and coolant tank, and some other little extras) but you can't easily just "add an intercooler" later... You would need a different intake manifold, and the stuff I just listed... definitely going to be expensive. If you're going to get it, get it from the start, otherwise use meth injection or nitrous.
Edit: Off topic, but by the way Cliff, made up a set of MIL's following your instructions (used 1/4 watt resistors) and all is well so far! A small hesitation has developed while "cold" (above C)and WOT... goes away once warm... that could be because I should probably clean my MAF and replace the fuel filter though. [8D]
ShadowDrake is offline
Old 05-07-2007, 11:50 PM
Yellow Fever
Yellow Fever's Avatar
3 feedback= buyer beware.I wouldn't touch that thing.
Yellow Fever is offline
Old 05-07-2007, 11:55 PM
wwmost
wwmost's Avatar
yea when it comes to those things i wouldnt get cheap on man. i mean if it stays below 3 grand then jump on it but no more then 3. if ur gonna do it, do it right the first time.
wwmost is offline
Old 05-08-2007, 12:12 AM
Sonic_BlueProCharge
[align=left]yeah if it stays below 3 i will buy it y not i guess i emailed the guy to find out if it comes with an innercooler no reply yet
[/align]
Old 05-08-2007, 12:16 AM
BleedinBlue
BleedinBlue's Avatar
ORIGINAL: Sonic_BlueProCharge
[/align]
No reply? If he doesn't answer soon, that is another sign of a scam. He probably can't even speak English and doesn't know what you asked [8D]
It is your money you are risking.
BleedinBlue is offline
Old 05-08-2007, 12:18 AM
Sonic_BlueProCharge
yeah i am going to wait on my bid unitll he replys only been a few mins thou i will give him a couple hrs..
Old 05-08-2007, 12:28 AM
bullitt1991
bullitt1991's Avatar
would you need a intercooler for a vortech mongoose kit?
bullitt1991 is offline
Old 05-08-2007, 12:37 AM
4.6BLKGT
4.6BLKGT's Avatar
you don't need an intercooler for a vortech, you will get more horespower from it,and you'll be able to run more psi,
4.6BLKGT is offline
Quick Reply: KB scam or not
