Non Pi heads...worth the problem?
Old 05-09-2007, 06:54 AM
koumiss45
koumiss45's Avatar
Default Non Pi heads...worth the problem?
I am looking to start building another motor from the ground up, but I would like to know: Is there any way to make the non pi heads flow anywhere near to the pi heads? I was thinking of picking up a set of non pi's and gaket porting them, you know the old school way. Even if I do succedd at the port matching, will the pi manifold ever bolt up or not. I can find non pi heads for a dime these days, and think it might be worth the 200 dollars saved to put a little port matching time in. If these wont work just say so....and I want to run stage 2 vt's in em if that matters.
koumiss45 is offline
Old 05-09-2007, 06:56 AM
2000GT4.6
2000GT4.6's Avatar
Default RE: Non Pi heads...worth the problem?
It will be almost impossible to do any hand port job by yourself and do anythign but hurt performance.
The NPI heads can be professionally ported to outflow stock PI heads... but PI heads can be ported to outflow ported NPI heads, so why start off with the crap NPI stuff?
You can buy an adapter kit to mount a PI intake onto the NPI heads, but once again its more expense for nothing. start with the PI heads.
2000GT4.6 is offline
Old 05-09-2007, 04:28 PM
droptoppony
droptoppony's Avatar
ported NPI's flow about the same as ported PI's...
droptoppony is offline
Old 05-09-2007, 08:17 PM
breagles
breagles's Avatar
non pi heads meke greta paperweights or a doorstop
breagles is offline
Old 05-09-2007, 08:53 PM
jEEd
I ♥ Acer
jEEd's Avatar
Steen Racing Port and Polish
Ported Non-PI Heads Stage I Stage II
Flow:
Intake: 190 cfm @ .550 204 cfm @ .550
Exhaust : 165 cfm @ .550 176 cfm @ .550
Ported PI Heads Stage IStage II
Flow:
Intake: 201 cfm @ .500 216 cfm @ .500
Exhaust : 170 cfm @ .500 181 cfm @ .500
the stage II is just adding ModMax Oversized Valves
cost for ModMax Oversized Valves -
NPI - $235
PI- $375
hopefully this helps ya.
jEEd is offline
Old 05-09-2007, 09:09 PM
silverstang1996
silverstang1996's Avatar
ORIGINAL: 2000GT4.6
not impossible. i've talked to a guy who has ported NPI heads himself, said it took alot of time, but didn't hurt his wallet as bad.
silverstang1996 is offline
Old 05-10-2007, 05:43 AM
koumiss45
koumiss45's Avatar
Hmmm....well screw that. I think I am going to go with a stock gt crank and iron block....I think. Where is the cheapest place to pick these up, and how much should I be paying for them?
Seanam
10-04-2015 10:15 AM
marc954
09-29-2015 03:05 PM
mdj89
09-23-2015 08:49 AM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: Non Pi heads...worth the problem?
