2000gt heads on a 98gt?
05-09-2007, 01:09 PM
Will they work, or did i waste my money?
05-09-2007, 01:24 PM
RE: 2000gt heads on a 98gt?
It's called a P.I. swap and yes it will work you should get a signifacant horsepower gain out of it!!!!
05-09-2007, 01:43 PM
make sure you get the cams and intakemanifold as well.
05-09-2007, 04:34 PM
Ive got all that but i saw earlier on here that the 99 and 2000 gt heads were windsor heads and my block is a romeo block i was wondering if that was true?
05-09-2007, 04:36 PM
The heads will swap right onto your car. Regardless of the shortblock (R or W) all the modular 2v stuff will bolt together.
However, I think the 98 has the same setup as the 99/00? I thought they changed over to the 6 bolt in 01?
05-09-2007, 04:38 PM
The thing is that you will need a couple of different timing cover bolts.. Randy over at MD will know what you need and get you all the little pieces
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
Florida Regional Chapter
09-30-2015 08:04 PM
Drastang
09-30-2015 03:48 AM
