Need help Check engine light
Old 05-09-2007, 09:12 PM
vinson581
vinson581's Avatar
Default Need help Check engine light
well i finished up my kenne bell install and started it up, it started a little rough and threw the check engine light, it is code p0113 - air intake iac high, so i thought i might have damaged the iac, i bought a new one installed it and i get the same code after i cleared it with my xcal, once the car is started it runs and drives and idles just as it should...any suggestions on my cel?
v581
vinson581 is offline
Old 05-09-2007, 09:20 PM
Topdog922
Topdog922's Avatar
Default RE: Need help Check engine light
explain your kenne bell whats that?
Topdog922 is offline
Old 05-09-2007, 10:05 PM
Fizzics Boy
Fizzics Boy's Avatar
ORIGINAL: Topdog922
Roots style blower.
Fizzics Boy is offline
Old 05-09-2007, 10:12 PM
vinson581
vinson581's Avatar
sorry to be vauge....kenne bell 1.7l supercharger. air to water intercooler @9lbs 42lb injectors, and 90mm maf and a whole buncha other ****
Old 05-10-2007, 02:03 PM
vinson581
vinson581's Avatar
any suggestions?
Old 05-10-2007, 02:14 PM
newb2000GT
newb2000GT's Avatar
Intake Air temp high is IAT but you are saying IAC. Which is it? I have replaced my IAT twice in a year-and-a-half with my procharger setup but have never had to dick around with my IAC. The IAT is only $12 at AutoZone so I never worried about why it goes out.
IAC (Idle Air Controller)= Idling issues when bad.
IAT (Intake Air Temperature) Sensor = p0113 code when bad (high intake temp code).
Your code is for an IAT sensor and is ver easy to replace on early new edge's but I don't know where it's at on a 2004, especially with a KB install. Mine was under the intake tube after the MAF prior to the blower installand post blower install it's even easier to get at on the new procharger intake tube.
newb2000GT is offline
Old 05-10-2007, 03:01 PM
vinson581
vinson581's Avatar
i realized my problem DUR!
01 + mustangs DO NOT HAVE A IAT they are intagrated into the maf....
by me repaceing my MAF with a 90MM lightening i took away the intagrated IAT sensor in the maf...
so now i realize all i have to do is splice the grey and grey / red wire (outermost) on the MAF and hook it to the IAT sensor and tap a hole into my Intake...does this sound right?
i ment IAT not IAC sorry about that...anyways my iac was starting to get sticky..
Old 05-10-2007, 03:06 PM
8banger
8banger's Avatar
Yes PO113 is for the IAT.....and I think you got it figured out...
8banger is offline
djbigskrilla
09-20-2022 01:04 AM
labudski
08-24-2015 07:23 AM
microgt
08-20-2015 07:12 AM
mweiland
08-13-2015 05:11 PM
drumhedd2005
08-13-2015 09:59 AM
Quick Reply: Need help Check engine light
