Cams with NPI Heads
Old 05-10-2007, 07:52 PM
steeda22
steeda22's Avatar
Default Cams with NPI Heads
Would getting say comp cams or some other pi cams be worth getting with the 98 gtNPI heads? I hear alot of peopleS/C there 96-98 gt withPI camsPI intake but using the npi heads that are stock. Thanks.
steeda22 is offline
Old 05-10-2007, 07:55 PM
RipTide7
RipTide7's Avatar
Default RE: Cams with NPI Heads
IM actualy looking for some used pi cams in the near future, you can pick em up for about $100 and if u install yourself thats a cheap 15hp. Or you can just upgrade thhe cams to aftermarket NPI cams, im not sure you can fit PI aftermarket cams in a NPI head, theres also PTV issues if you go .550.
RipTide7 is offline
Old 05-11-2007, 02:37 AM
droptoppony
droptoppony's Avatar
You can use aftermarket PI cams in NPI heads but some things need to be changed...spring perches need to be machined and or Crower offset retainers.
droptoppony is offline
Old 05-11-2007, 03:10 AM
2000GT4.6
2000GT4.6's Avatar
ORIGINAL: droptoppony
Don't you have to watch the PTV clearance with the PI aftermarket cams usually running a .550 lift?
2000GT4.6 is offline
Old 05-11-2007, 12:13 PM
droptoppony
ORIGINAL: 2000GT4.6
No why? PTV contactoccurs on the outer skirt of the piston so dish size is irrelevant to where the PTV takes place. A properly deegreed in set of cams won't have PTV
Old 05-11-2007, 12:15 PM
97stanger
97stanger's Avatar
You shouldn't even have to touch your heads before maxing out your motor if you go with full bolt ons/blower/intake/cams on a NON PI headed car.
97stanger is offline
GimpyHSHS
19
12-19-2023 01:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Florida Regional Chapter
09-30-2015 08:04 PM
Drastang
09-30-2015 03:48 AM
Quick Reply: Cams with NPI Heads
