OEM Brakes
OEM Brakes
Is there a place I can order OEM Ford Rear Brakes for my 1998 Mustang GT with disc brakes? The dealer wants $90 for them, but I want to know if theres a cheaper way to get OEM parts for the stang?</P>
Also, will I be able to install the brakes myself? Thanks for the help stang owners!</P>
OEM Brakes
Rear disc brakes are easy. Make sure you turn the rotors and have them check for minimun thickness. if too thin you will also need new rotors. You can go with a good aftermarket brake pad not the cheap ones but OEM would be better. I work for a ford dealer and do brakes all the time take your time and always do one side at a time and don't screw up you could kill someone or even yourself. Good luck
OEM Brakes
get yourself a manual to help..read it first then start...like about thier easy...you can get pads anywhere..rayabostes is one of the best like around 35-40 buck...have the rotors turned to have them trued..bleed them also...while doing that check your front one's and check for leaks and all those good things
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
