flooded stang wont start
Old 05-26-2007, 12:18 PM
jusnkris
jusnkris's Avatar
Default flooded stang wont start
well thanks to the central texas flooding my mustang fell victim to the elements. buried it in a foot of water at about 20 mph right by my house luckily. pushed it up to my house and let it sit all day yesterday with the battery disconnected. it wont crank over, just one big lug when i turn the ignition switch. what can i do to get it started again?
jusnkris is offline
Old 05-26-2007, 12:48 PM
jst854
jst854's Avatar
Default RE: flooded stang wont start
you might have water in the cylinder, do not try to crank it over. Water is not compressable and your enigne will throw a rod. Take out the plugs and turn it over to push all of the water out of the cylinders, you might also need some new plugs.
jst854 is offline
Old 05-26-2007, 01:03 PM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
You also need to drain all the fluids and flush all the systems.
JD1969 is offline
Old 05-26-2007, 04:46 PM
white venom
baby poop
white venom's Avatar
i live in the fort worth area. that SAME **** happen to me a few months ago. just let it sit and the water will eventually evaporate and it will start sooner or later. i was so scared at first. haha
white venom is offline
Old 05-26-2007, 05:33 PM
02WhiteGTVert
02WhiteGTVert's Avatar
make sure you put a new air filter in it,or clean the one you have if it's a K&N style. if the filter's even slightly damp,it'll cause it to misfire all to hell when it sucks that moisture through.
02WhiteGTVert is offline
Old 05-26-2007, 06:44 PM
cahtr6
cahtr6's Avatar
ORIGINAL: gilbert00
It didn't evaporate but it will leak in to your oil.
cahtr6 is offline
Old 03-02-2015, 05:22 PM
bryancaudill
bryancaudill's Avatar
And then what if it does leak into your oil? Just flush it? Or will I need a new block?
bryancaudill is offline
bjdutch2005
03-24-2017 03:38 AM
2007StangV6
01-28-2016 06:09 PM
StalkerGT
09-25-2015 02:41 PM
Luke9222
09-04-2015 06:46 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: flooded stang wont start
