I need help, massive coolant leak behind alternator.
99 GT 5 spd, was out driving today and when I stopped a bunch of steam was coming out from the hood. I drove home as fast as I could and once everything got cooled down I refilled the anti freeze and started it up and it looks like a damn green waterfall behind the alternator. What the hell did I do? My buddy says to check for a busted coolant bypass hose to the water pump, others have said it could be a cracked intake manifold which I hope it's not cause i can in no way afford that. Any ideas on what I should look at when I tear it down tomorrow?
RE: I need help, massive coolant leak behind alternator.
Do I dare run the car with no alternator on it? When I run it with the alternator on it seriously looks like a little green waterfall right behind the alternator coming from up above. It scares me.
Then it is for sure the crossover. Sorry. Try taking it the the dealer and make them fix it under the TSB
https://mustangforums.com/recalls-an...d_0222/TSB.htm
I would love to try that but with the amount of leaking I have going on I won't be taking the car anywhere, guess I'll just have to get one off ebay and see if I can throw it on without destroying anything important... damn that's bad luck, only had the car a week and a half..
