vent stuck on defrost
Old 06-04-2007, 06:32 PM
jst854
jst854's Avatar
Default vent stuck on defrost
No matter what i have it set to the vents blow on defrost. I just swapped a pi intake in and was wondering if i might have screwed something up while doing this.
jst854 is offline
Old 06-05-2007, 11:56 AM
m1950
m1950's Avatar
Default RE: vent stuck on defrost
there is a small vaccuum line on the firewall right where ther heater core lines come out of the wall check to see if it is connected and also did you have any work done behind the stereo.
m1950 is offline
Old 06-05-2007, 04:13 PM
jst854
jst854's Avatar
I did put a new radio in but that was about six months ago and it worked fine then, I will check that vacum line by the firewall
jst854 is offline
Old 06-05-2007, 04:28 PM
BoostedBoxer
BoostedBoxer's Avatar
It's definately a vacuum problem. Whenever there is no vacuum to the HVAC controls they revert to defrost. Same thing happened to my work truck.
BoostedBoxer is offline
Old 06-05-2007, 04:52 PM
HOLLYWOOD99
HOLLYWOOD99's Avatar
vaccum prob, not fun... just check em all! its probably a line to the VACCUM ACCUMULATOR in the engine bay..
HOLLYWOOD99 is offline
Old 06-05-2007, 07:47 PM
m1950
m1950's Avatar
also check behind the stereo there are some lines the go to the control.
m1950 is offline
Old 06-06-2007, 08:28 AM
contentsunderpressur
contentsunderpressur's Avatar
+1 on the line coming from the firewall. That is the only line that pulls vacume for the AC andit's very easy to break or unplug that brittle POS.
contentsunderpressur is offline
Old 06-06-2007, 08:30 AM
2000GT4.6
2000GT4.6's Avatar
ORIGINAL: BoostedBoxer
+1
2000GT4.6 is offline
Old 06-06-2007, 12:08 PM
jst854
jst854's Avatar
I am pretty sure that it is the vaccum line from the firewall. There is a hose hanging done there and it was resting on the block and it melted. Where does this hook up and what do you guys suggest that I do.
jst854 is offline
Old 06-06-2007, 05:44 PM
jst854
jst854's Avatar
anybody, where does this line hook up to and how do i replace it, how do i get it out of and back into the firewall?
jst854 is offline
Quick Reply: vent stuck on defrost
