thermostat
Old 01-14-2005, 10:59 PM
Guest
Guest
Posts: n/a
Default thermostat
What is the stock thermostat set at? 190 degrees? Anyone running a colder than stock thermo on their car? I hear mixed reviews about it, one says its good to have the car run cooler than normal for performance reasons, and another will say that the car was built with a certain temp from the factory in mind for the reason that it simply runs the best at that temp.
Any thoughts?
Old 01-14-2005, 11:44 PM
mysticsvtcobra96
mysticsvtcobra96's Avatar
Default RE: thermostat
Yes it runs perfect from the factory but whenever you start doing mods and generating more horsepower then that causes more heat then the factory colling was designed for an thats when you get into looking for a 160 degree thermo..its a must if you get a chip or anything that advances your timing..hope that help ya out
mysticsvtcobra96 is offline
Old 01-15-2005, 02:20 AM
code3GT
Mustang Nazi
code3GT's Avatar
Run 160's in both Stangs.
code3GT is offline
Old 01-15-2005, 04:05 AM
neogenic83
neogenic83's Avatar
I have always heard 160 is too cold for N/A cars. but ofcourse I could be wrong. happy with my 180 may have to try the 160 and see what the results are
neogenic83 is offline
Old 01-15-2005, 04:06 AM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
A majority of your fuel injected cars need to be around 190-220 degrees to run at their full potential.
It's bad for your rings to run too cool...
Dan04COBRA is offline
Old 01-15-2005, 05:52 AM
00GT00
00GT00's Avatar
^^^^ What he said! But in the MOD family a 180* should be cool (no pun intended)! They run hot compared to other engines, ie: Honda, and the one that starts with a 'C' etc.
I have a 180 T*stat, I think it improved the stability of my car. Better idle quality and all-around performance!
(edit) Its 1 in the morning! WTF!
00GT00 is offline
Nick Oliver
10-17-2018 04:22 AM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
MusicCity615
09-12-2015 07:05 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Wesley1995
08-30-2015 02:01 PM
Quick Reply: thermostat
