PO340 code
Old 07-12-2007, 10:59 AM
Brute03
Brute03's Avatar
Default RE: PO340 code
just to clarify, the alt didn't blow the sensor out especially since it's a halls effect sensor, it was only interfering with the signal that it sends to the PCM (both the cps and alt are on the same harness)
Brute03 is offline
Old 07-12-2007, 11:41 AM
BBZracing
BBZracing's Avatar
I am not a mechanic so I don't know the correct terminology. All I know is I did my research and read that a bad alternator can blow out the cam shaft sensor. I replaced the alternator and the problem was fixed. [/align][/align]Just trying to help the guy out.[/align]
BBZracing is offline
Old 07-12-2007, 12:19 PM
8banger
8banger's Avatar
ORIGINAL: Brute03
Exactly..
8banger is offline
Old 05-21-2012, 07:51 PM
GrySql
GrySql's Avatar
I just registered so I could say 'Thank You!' for the expert help.
My 2003 GT threw the P0340 code, I parked it immediately.
I found this website that described the alternator as the solution, it was.
No CPS needed.
Your advice made a seemingly difficult problem easy to fix.
GrySql is offline
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: PO340 code
