Go Back   MustangForums.com > Ford Mustang Tech > 4.6L (1996-2004 Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 05-21-2008, 05:28 PM   #11
amoosenamedhank
amoosenamedhank's Avatar
Vehicle: 1996 GT
Default RE: 5.4L Intake?
Quote:
ORIGINAL: 97mustanggton18s
What are the benifits to using a 5.4 intake?
Benifits to using a 5.4 intake on what?
__________________
BUY MY SUPERCHARGER!
amoosenamedhank is online now   Reply With Quote
Old 05-21-2008, 05:30 PM   #12
johnr2001gt
the intake will not work without adapters. I have done a 5.4 swap and to use the 4.6 intake we had to buy the adapters or vise versa. believe it or not autozone can get the adapter plates for you thats where we ordered them from. they where like close to 300 if I remember correctly.
__________________
03 Mach 1, full eaton swap and more 443 RWHP
johnr2001gt is offline   Reply With Quote
Old 05-21-2008, 06:17 PM   #13
jhell00
Possible Scammer
Vehicle: 00 mustang gt
so could you use the supercharged lightning itake with the supercharger on the mustangs?
jhell00 is offline   Reply With Quote
Old 05-21-2008, 07:36 PM   #14
amoosenamedhank
Vehicle: 1996 GT
Quote:
ORIGINAL: jhell00
Yes but you would be better off using a KB because the stock eaton is huge.
__________________
Old 05-21-2008, 09:43 PM   #15
sxynerd
1996 Ford Mustang
My Garage
sxynerd's Avatar
Vehicle: Stock 96 GT
Send a message via AIM to sxynerd Send a message via Yahoo to sxynerd
Quote:
ORIGINAL: amoosenamedhank
Quote:
ORIGINAL: jhell00
It's not that BIG!
http://videos.streetfire.net/video/F...ngi_160002.htm
__________________
PLEASE JOIN MY MUSTANG FACEBOOK GROUP, Club Chapters in Michigan, Indiana, Tennessee & Louisiana. EVENTS PLANNED FOR ALL ACROSS THE US and not limited to just the club. MF.com events are also listed.
http://www.facebook.com/groups.php?r...d=252526394357
sxynerd is online now   Reply With Quote
Old 05-21-2008, 09:45 PM   #16
ponysnake99
ponysnake99's Avatar
Kar Kraft sells intake adapters in multiple forms. They sell 5.0 and late model cobra intake adapters...671, carb, weber adapters, the list goes on.
__________________
Parting out a '99 Cobra! PM me to see if parts are still available!
- Steeda MIL eliminators, < 500 miles on them.
- Cobra Front brakes/powerslot rotors
- Assembled Tumbleport DOHC heads
ponysnake99 is offline   Reply With Quote
Old 05-21-2008, 10:13 PM   #17
jhell00
Possible Scammer
so what would be needed to do it adapter plates manifold and supercharger obviously! need to move the alternator somehow?
Old 05-21-2008, 11:09 PM   #18
amoosenamedhank
Vehicle: 1996 GT
Quote:
ORIGINAL: jhell00
Oh no you can't do that. I thought you meant a s/c 5.4 in a mustang. Well I suppose you could do it but it would be a lot of work. Similar to putting the 03 cobras eaton on a 2v. I think there is a sticky about why that's a horrible idea.
__________________
Old 06-21-2008, 12:07 AM   #19
sweet99
Vehicle: 1999 Ford Mustang
Well I may do the 5.4 swap but need ACCURATE INFO! Which adapter plate works the best? Would my SVO ported to PI heads work or should I go with the stock plastic intake and 70mm TB./plenum with torque the goal? It seems the SVO with adapters would place the COP's too high to make proper contact with the spark plugs so I think I aswered my own ?.
Cam choice is Crower stage 2 for npi heads as I will use NEWV Stock springs, this motor is not a high rpm motor. Specs are .532"/.532" & 220224* on a 114* LSA. Stock cams are 200209* and my present SHM #2730's have 230* duration, way too much even for 4.10's and 2800rpm stall converter. I have a 3400rpm stall converter now that locks at WOT in 2nd and 3rd gears and at part throttle in 2nd gear, nice, dropped .2 with the locks!
I will go with ebay Mahle flat tops and forged rods whose name I cannot rrmember, saves 2 lbs. of rotating weight. 10.x:1 compression. 5.4 has the pistons .100" in the hole so compression needs to be determined as I don't have the stock specs to use for comparison. Such as piston cc and head cc, anyone know?
The plates are the main issue as I have heard of leaks and misfit but maybe that has changed. Anyone have experience since this thread was started and how does a 5.4 run compared to a 4.6!
__________________
'99 GT Convertible/automatic.
4.10's(forsale-complete differential, in the spring!) PYPES catted X-pipe, Steeda UDP's (FOR SALE),Recommend Brenspeed.com/SVO intake, Hitech stage 2's.2V Teksid build started.
sweet99 is offline   Reply With Quote
Old 06-21-2008, 12:15 AM   #20
FRPRACN
Send a message via AIM to FRPRACN
Hello.. I can make any 4.6 or 5.4 inake you like for mild to wild.. spacer's bolt distributors ect.. Interested? look me up.. www.frpracn.com Thanks Daniel FRP RACING
__________________
Thanks Daniel FRP RACING Custom Sheet metal intakes for the 4.6 and 5.4's
FRPRACN is offline   Reply With Quote
54, 54l, adapters, deck, dohc, flat, height, intake, mahle, mmr, racing, reichard, sequence, top, torque
Similar Threads
5.4L Lightning swap siwelk 4.6L (1996-2004 Modular) Mustang 29 10-27-2006 01:41 AM
Whats with all the 5.4L posts? 2000GT4.6 4.6L (1996-2004 Modular) Mustang 26 06-07-2006 12:42 AM
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
