Forged Bottom
RE: Forged Bottom
My goal is around 650 rwhp. I plan to do a turbo kit at around 15 psi. so I do want the crank. From what I have seen with all the other stuff you need to buy you are only saving a couple hundred bucks in the end. And considering the differance of possible power, I don't see why you wouldn't go for more. The differance of running <500hp and 500+ is a forged bottom end. So if you are going to forge part, why not go all the way. If your going to over 500hp, you should be running a trubo kit, do to efficiency and a list of other reasons. And the differance between 500 and 800 hp is injectors and a tune. So why wouldn't you just go all the way. Thats what I figure.
RE: Forged Bottom
You plan on going turbo but still keep the cost down...? Not gonna happen. Building your own or buying a kit? You will be happier in the end if you forge the crank, plus you can rev higher.
What I would do is go forced induction first. Go ahead and safely max out the stock internals. Then save for a forged bottom. At least this way you will still be pretty fast.
RE: Forged Bottom
ORIGINAL: ajmodelski
No offence dude, but I hear this "Im going for 650rwhp" all the time and most of the people havent even driven 400rwhp cars...If you are actually going to follow through with your goal then yeah, purchase a new crank for it. Dont get offended, but Ill believe it when I see it.
RE: Forged Bottom
I have not driven a 400whp car before. But I have driven a 350 whp subaru and I am on a hydroplane racing crew. I know how my mind works, and I know that when I have 400hp. I'm going to want 500 and when I have 500, I'm going to want 600. 650 is the peak I will allow my self. As for keeping the cast down by buying the kit now and forging the bottom later. Not worth it. I don't want to put all that **** on more than once. And a full forged assembly with berrings and everything is $1800. An easy cast compared to the $5000 for a trubo kit. I hope that when I install my mods up to the point when I want the Turbo kit, I'm happy with thepower output. But I know I wont be.
69MustangCoupe393cid
10-03-2015 10:33 AM
maestro1024
09-21-2015 02:40 PM
