turbo?
RE: turbo?
also i forgot to mention if i go turbo route it will be a DIY/junkyard setup. i have decent fabrication skills. is there any junkyard turbo that i could use that will keep me in the 400 to 500 horse range. ie maybe a diesel turbo or something.
RE: turbo?
ORIGINAL: livefast1
what size single turbo would i need? i would like to run around 400 horses on stock internals and then maybe after a while get forged andbump up to 500.
RE: turbo?
yea i know that i plan on a tko 500 in the future. and i plan on making 500 on forged internals. i know if i dont get a HUGE single turbo i wont have to worry too much about lag. i figured maybe like a single t4 would be fine for 400 to 500 horses. i want a single turbo because i would be doing it myself and its alot less work. ie half the lines, half the fabrication for piping, whatever else.
RE: turbo?
Get a Master Power T70 turbo with a .68 a/r. It will run you about $585-$630. Remember though, even DIY turbo kits get expensive on our cars. Don't forget to get a tubular k-member, a-arms, and coilover unless you don't mind hitting everything! For exhaust manifolds, look into Turbocharged Innovation. The guy will make you some ceramic turbo manifold for $650 and they are great quality. As for using a junkyard turbo, I have seen many on older mustangs but not new edges. It's probably not a good thing to do, and it won't make as much power.
Since you are interested in turbos, go to theturboforum.com. They have a modular sections with tons of experienced guys running turbos.
RE: turbo?
thanx yea ive always wanted the upr front end kit. my dad has his own shop and i have pretty decent welding skills. if i got a junkyard turbo id rebuild it. isnt the turbo you listed pretty big?
RE: turbo?
if you do get a junkyard turbo ( i reccomend 2 T3's) make sure it hasnt seized up and that it doesnt wobble or anything when it spins. save you the hassle of a rebuild that would be more than its worth.
RE: turbo?
ORIGINAL: 2002GTAUTOVERT
