HELP - Starting System Problem - MustangForums.com
Old 03-25-2003, 07:41 PM   #1
BlackGT
Default HELP - Starting System Problem
Recently my 97 4.6 GT failed to respond when I turned the key to start it. My first thought was that the clutch switch did not complete the starter circuit since the car would not even click when I would turn the key. I then bypassed the switch by shorting the two wires and the car started.
Since then the car occaisionally(1 out of 10)does not crank when I turn the key. To get it to crank I push the car just a few inches to slightly turn the motor and then it will crank when I turn the key. Bizarre! any suggestions?
BlackGT is offline   Reply With Quote
Old 04-02-2003, 01:24 PM   #2
BlackGT
It was a bad starter.
Did a few mods this summer... drfister 2005-2014 Mustangs 9 09-04-2015 08:47 AM
Alternator problem? jjwinel78 V6 (1994-2004) Mustangs 1 08-17-2015 04:34 PM
1989 starting problems, engine won't turn over. KEM Motorworks 5.0L (1979-1995) Mustang 20 08-14-2015 11:13 PM
Need Help Diagnosing Have Codes (Confused) djbigskrilla 2005-2014 Mustangs 13 08-11-2015 01:59 PM
Raxiom Nav System from AmericanMuscle - Really??? dseg AmericanMuscle.com 2 08-10-2015 04:29 PM
