Car won't drive properly with new H-pipe
Grateful for any advice: I recently installed an off-road H-pipe with MIL eliminators on my '99 GT. Started it up, sounded great! Drove around for a few miles no problems at all. Then I seemed to lose power and ever since the car won't accelerate properly and I can't even get above about 45 mph. It's also goneunusually quiet.I've tried resetting the PCM but it's made no difference. I haven't got a SES light and nothing appears to beout of place.Please help!
RE: Car won't drive properly with new H-pipe
if i remember correctly, you lose a lil lower end pwr because of the loss of cats = no back pressure.
but thats pretty odd that you cant go over 45mph after installing an OR H-Pipe.
did you make sure everything was in properly? 02 Sensors & MILs. also if you have an exhaust leak?
Check the connection and installation on your 02 sensors and MILs. Also check connection of the H-Pipe with the manifolds. If its leaking before the 02s then it might be throwing off your readings.
I can't find/feel/hear any exhaust leaks and the O2 sensors are all tight andplugged in OK. No ticking noises.Weird how it ran well at first. Would a small exhaust leak really cause that much ofa problem? I mean there is almost NO power, it takes a really long time to get up to 40-odd. It's also extremely quiet, I can hardly hear the exhaust noteat all on tick-over whereas it was pretty loud before. I've just disconnected the battery again and will leave it a couple of days, clutching at strawsin the hope of better-resetting the PCM. Any other ideas??
I dont know if this would cause a problem but did you make sure there was no packing material in the H-Pipe? Something clogging it up? If there is something clogging it up you can probably tell by the exhaust before the clog getting almost red hot. I doubt that is your problem though. When I installed my long tubes and full exhaust I had problems and it was the O2 sensors that went bad. The ECM wont throw an O2 sensor code until the 3rd consecutive failure. Try running the car for a few minutes then shut it off, and do this a couple more times and see if you get a CEL (check engine light). Or maybe you disconnected something else that has nothing to do with what you worked on, the O2 sensor harness goes connected to a bigger plug if I remember correctly, maybe when you pulled the O2 sensor harness, something else unplugged? Well good luck, I threw a bunch of stuff out there that you can try atleast.
not trying to be a smarta$$ but did you put the mil eliminators on the back o2 sensors where there supposed to be or did you maybe accidently put them on the front ones.
ORIGINAL: livefast1
