Door locks & Trunk button stopped working
Old 09-04-2007, 08:43 AM
steedondubs
steedondubs's Avatar
Default Door locks & Trunk button stopped working
I checked all fuses & they read fine. My remote still communicates with the theft system, and recently my driver side window stopped rolling down for small periods of time... What the hell is up?
steedondubs is offline
Old 09-04-2007, 08:54 AM
bjh061487
bjh061487's Avatar
Default RE: Door locks & Trunk button stopped working
dunno what is up with the window. maybe a bad motor.
as for the door trunk and locks try and re program them. i dunno what year yours is (from the hood its a 96-98) but mine is a 98 and when i bought the key fab i had to program it to my car. there is a black box on the driver side under the carpet in the trunk. you should see two pins sticking out. complete the circuit with a paper clip or something metal and then just keep pressing the lock button. also before that, check the batteries. my uncle's fab died and he didn't know that they ran on batteries so it maybe just a small step you have overlooked. good luck thou
bjh061487 is offline
Old 09-04-2007, 09:03 AM
Stonewall83
Stonewall83's Avatar
its most likely a fuse. check double check and check again
get a test light and check both sides of the fuse while its still installed.
keep us posted
Stonewall83 is offline
Old 12-19-2007, 04:31 AM
steedondubs
It was a fuse under the dash. I missed it. What a ****ty place for a fuse box
Old 12-19-2007, 09:46 PM
lewistk
lewistk's Avatar
oh man, yeah it really is!
lewistk is offline
Old 12-19-2007, 09:59 PM
99gt302
99gt302's Avatar
mine did that a couple of times. It started where if I pressed the panic button it would de program. I re programmed it and it worked fine. One day it did it but wouldnt re program. I took the battery off for about 30 minutes, re programmed, and not its fine. ANd it dosent de program if I press the panic button any more, I have no idea why it did it.
99gt302 is offline
Bullet 67
09-18-2015 08:00 AM
stormesixx
08-25-2015 09:11 AM
Tyoung68
08-25-2015 04:31 AM
Bullet 67
08-24-2015 07:02 AM
inyadreems
08-21-2015 09:10 AM
Quick Reply: Door locks & Trunk button stopped working
