Stumble during acceleration
Old 12-13-2007, 06:36 PM
lewistk
lewistk's Avatar
Default RE: Stumble during acceleration
ORIGINAL: incubus1275
it seems like nobody ever checks out EGR, evap, or any of the emission systems. They can too create the same problems you are mentioning if not working properly.
what sort of emission system checks do you mean? i have already checked egr btw...
lewistk is offline
Old 12-13-2007, 07:54 PM
vertmustang98gt
vertmustang98gt's Avatar
like I said above change the TPS it is very common for the car to idle funny. Mine did the same thing and then once I switched it has not done it since.
vertmustang98gt is offline
Old 12-17-2007, 12:42 PM
97_mustanggt
97_mustanggt's Avatar
my 97 gt was doing the same thing and my problem was a blown head gasket. but it was leaking the coolant into the cylinders leaving thick goop on my sparks plugs.
97_mustanggt is offline
Old 12-17-2007, 02:09 PM
uberstang1
Chupacabra
uberstang1's Avatar
The Evap system will not effect how the car performs its strickly for emissions purposes, aka "save the planet"
uberstang1 is offline
Old 12-17-2007, 05:09 PM
lewistk
lewistk's Avatar
after you fixed your head gasket did it run ok?
lewistk is offline
Old 06-28-2018, 09:54 PM
Joe Fowler
Joe Fowler's Avatar
I have the same problem, replaced the fuel pump. Filter, fuel tank itself since the bracket that holds fuel pump was broken Still cannot figure out what is wrong, im aiming towards the coil pack. But when my car stumbles, all the gauges also reset? Swipe right and left and start up again like i just turned the key on? Any ideas??
Joe Fowler is offline
Old 07-02-2018, 10:27 AM
WJL
WJL's Avatar
As mentioned earlier in this old post, don't just start replacing parts. if you take a test light to ground, pull the plug wire off the coil pack and hold the test light probe above the coil tower and crank you should see spark which means the coil is good.
its a wasted spark system and i don't remember the pairs but 2 & 6 fire at the same time 1 & 5 and so on.
could be an egr problem this also can be checked good luck
WJL is offline
Old 02-04-2022, 05:40 AM
Richiecuz88
Richiecuz88's Avatar
I've had very similar symptoms and come to find out once I replaced the cranksensor the problem went away.
Richiecuz88 is offline
StockD15b
10-12-2010 10:29 PM
carlitoselcool
12-09-2009 08:44 PM
nick_thames
12-22-2007 09:15 AM
DriftAngle45
08-12-2004 09:16 PM
mustangdave357
04-15-2004 11:08 PM
Quick Reply: Stumble during acceleration
