wierd! my gauges have started sweeping on startup!
Old 10-30-2007, 09:10 PM
bigtom
bigtom's Avatar
Default wierd! my gauges have started sweeping on startup!
My gauges have started sweeping on startup! I know too some people that is cool or desirable but I didnt do any thing to the car. to make it start doing that!
Anyone else had this happen? Any ideas?
bigtom is offline
Old 10-30-2007, 09:24 PM
dtkikols
dtkikols's Avatar
Default RE: wierd! my gauges have started sweeping on startup!
YES mine are doing the same thing. i dont know what it is. im gonna go get my battery checked.
dtkikols is offline
Old 10-30-2007, 09:34 PM
bigtom
bigtom's Avatar
ORIGINAL: dtkikols
Yeah that might be it, Ihavent takenthe mustang out that much recently but i noticed this morning that it was doing it. maybe it s just because i had it sat for a week and the batt needed charging? On the other hand the car is nearly 7 years old with bout 75k on it maybe a new batt might be due?
bigtom is offline
Old 10-30-2007, 09:35 PM
mvr
mvr's Avatar
only time ive had that happen is the first time i started the car after i took the cluster out to install my overlays.
mvr is offline
Old 10-30-2007, 09:42 PM
Epinephrine186
Epinephrine186's Avatar
mine was doin that...i replaced terminals and it stopped doin that.
Epinephrine186 is offline
Old 10-30-2007, 09:43 PM
01GT4.6
01GT4.6's Avatar
time for a new battery.
01GT4.6 is offline
Old 10-30-2007, 09:49 PM
defconfire
defconfire's Avatar
The only time mine has ever done that, without me holding the odometer button on startup, was when I wanted to try that thing that shuts off your fuel rails (press the gas down all the way and crank it). I did it for a while and then they did the sweeping thing but it does make sense that it would be the battery.
defconfire is offline
Old 10-30-2007, 09:59 PM
bigtom
bigtom's Avatar
I appreciate all the help guys, recon i will check the battery. Im not exactly in the money right now! do you think a cheap autozone type batt will be ok?
bigtom is offline
Old 10-31-2007, 04:55 AM
contentsunderpressur
contentsunderpressur's Avatar
Mines done that also. It does that when it looses all power for a split second. Mine was the battery but it could also be the battery cable ends or the battery cables.
contentsunderpressur is offline
Old 10-31-2007, 09:58 AM
02GTSteve
02GTSteve's Avatar
Mine started that last Monday and by Friday I had to replace the battery because I had nothing left on the old battery. Better get a new one before you get stranded.
02GTSteve is offline
Quick Reply: wierd! my gauges have started sweeping on startup!
