service engine soon light!! wtf
RE: service engine soon light!! wtf
ORIGINAL: uberstang1
If you never got it checked before how do you know its for something emissions related, the CEL can come on for tons of different reasons that are not emissions related.
i am going to get it checked today and let you know.
yay easy guys dont need any violence when i said emmissions i said that because when i looked that light up in the owners manual it says "emmissions". i went to advanved and he said there were accually 2 codes. both had to do with a "bank" running too lean... and he cleared it for me. it has not come back on yet but its only been a few hours. i have had the car for a little over a month with no light. how do you know if you have "mil" whatevers on it and what are they. he did not give me the code numbers though.
If it has to do with the banks running lean, it isyour Xpipe.. Is it an O/R pipe? Your O2 sensors are throwing a code because you dont have cats anymore. It will probably be back on shortly. You will have to get under your car and see if there are any mil eliminators... you will see them attached after your o2 sensors on your mid pipe. They might have burnt out. How many miles do you have on the car?
As far as having an offroad mid pipe goes, the 2 rear o2 sensors which are the ones after the car serve no function except to check to make sure the cats are working properly. The installation of an aftermarket midpipe shouldnt cause a code to be thrown for a lean or rich. Generally you get a code for cat defeincy when u have a catless midpipe. If that lean code is being thrown by one of the 2 front 02 sensors that isnt because of your midpipe, i would recommend not hammering on that car or takeing it to redline till you poinpoint the problem.
ok now its pissing me off. the light came back on after a few hours and the idel vareation also came back. i have 54k miles. so ill get the code read again tommorow and get the code numbers. so the code numbers will tell me witch of the 4 02 sensors it is? the guy said it was 2 lean codes can both the front sensors go out at the same time.is that the only thingthat will throw a lean code? why would you feel a little idel change when the light comes on but you clear the code it is fine. i feel no power change when the code came on. ill post the codes tommorow. oh my fat *** cant fit under the car to look for a mil eliminator.
i have this exact same problem. but i dont have a mid-pipe, my codes were p0171 and p0174. ive been trying to figure out what the problem could be. just to help wth suggestions ive replaced my iac, smoketested my engine novaccum leaks anywhere, and replaced my fuel filter.
Here is some other stuff that can throw the p0171 code:
1. Dipstick tube sucking air - bad seal
2. PCV hoses sucking air.
3. Cracked air intake tube between MAF and throttle body - pull it and check
it carefully for cracks.
4. EGR valve loose, or leaking.
5. Tube from exhaust manifold to EGR valve cracked, or loose
6. Hose from fuel vapor recirc system (evap solenoid) to intake manifold
cracked or leaking.
7. Loose throttle body bolts
8. Exhaust system leak before O2 sensors (since you are setting p0174 that
would require 2 leaks)
cracked or leaking.
ok now its pissing me off. the light came back on after a few hours and the idel vareation also came back. i have 54k miles. so ill get the code read again tommorow and get the code numbers. so the code numbers will tell me witch of the 4 02 sensors it is? the guy said it was 2 lean codes can both the front sensors go out at the same time.is that the only thing that will throw a lean code? why would you feel a little idel change when the light comes on but you clear the code it is fine. i feel no power change when the code came on. ill post the codes tommorow. oh my fat *** cant fit under the car to look for a mil eliminator.
