Stupid spark plugs...
Okay I have a question about spark plugs. This is my first time changing them in my mustang, or in any COP application, and it's turning out to be a little more of a challenge than I thought. I'm at a point where I am going to start running out of time. Is it okay to run with some of the plugs changed and the others still with old plugs or should I backout and put the old plugs that I've taken out, back in. Thanks.
RE: Stupid spark plugs...
lol...well it's kinda been one of those things where nothing is going right. I couldn't find my plug socket, which i think a neighbor borrowed and never brought back, plus I didn't have the right extension, again thanx to the neighbor, so I had to put 2 3" extensions together one 3/8 and one 1/2 with adapters then my socket is really tough to get on the plugs because the rubber is so new. But I got one plug out and I wasa little nervous after I started reading how many people are blowing plugs out of the heads so I torqued it down to 15lbs and now I can't get the socket off. So it's just been a series of things not all necesserely related to the actual work of changing the plugs.
What a pain in my A$$! So i ended up taking the new plug I had put in back out and it took me 15 min to get that plug out of the socket. I had to pry with a screw driver on a lip pulling it up out of the socket. Then put a small screw driver in the backside of the socket pushing it out and then using pliers to help pry it out and it finally came out. So I took my drill and bored out the rubber in there a little bit. There's no way I was going getting that socket off of the plug with it installed. But 1 plug down and it runs fine so the rest should be a piece of cake...yea right.
never heard of blowing a plug out of the head until I read it on this forum. how the hell does that happen? I don't see how that can be a very common occurence. ive always just torqued them down based on feel and never had a problem.
Before Ford revised the design of the head there were onlyfive or sothreads for the plugs. If you cross-threaded the plugs, torqued em too much or stripped a thread or two the plug would only be held in by a few threads. After a while the threads would give out from the combustion forces an just fly out.
