i need help from everyone
RE: i need help from everyone
ya i have the same problem once in awhile and i cleaned my IAC and it didnt help, where can you buy that special tool the hexhead with the hole in the middle to get the MAF sensor out so i can clean that?
http://www.muscularmustangs.com/iac.phpthis might help. its in a different spot on an 02 but you can get an idea of what to do
Also check your PCV. PCVs get grindy and dirty and start to stick after a while. They're all about vaccuum so they're all about idle as well. Plus they'relike $2.00
Here's a link:
http://www.partsamerica.com/ProductD...=5&PTSet=A
Here's a link:
I wouldn't like an idle at 500 rpms anyway. It should be at about 650-675 rpms. Like everyone said check the IAC, MAF sensor, a tune up couldn't hurt, and check the fuel filteer.
ORIGINAL: sleeping stallion
ok so i have a 02 gt with some mods. my car usualy idels at about 500rpm. so the other day i came to a stop and the rpm dropped to about 250 and then went back up then down then up. it sounded like it was gonna die. can anyone point me in the right direction
ORIGINAL: 99BlackPonyGT
500???? my car idles at 1200 cold and when its warm im 900-1000 ....yea its a little high, but 500 seems wayyyyyy too low
