injector install and fuel filter
#31
RE: injector install and fuel filter
The part number you are looking for for the pink 21lbs is 1F2E-B4A and the part number you have now with the orange 19lbs is YR3E-A4A. So you see there are 2 different part numbers for each. Why do people doubt me.
#32
ORIGINAL: oxfordgt
#33
okay, bought used pink injectors from a guy on another forum. They only had 14k miles and the o-rings looked fine so i just put some oil on the rings and popped them in. The car is running great, i changed the fuel filter and the parts store sold me the wrong tool, it said ford fuel line removal tool and it was 5/8', its actually supposed to be 5/16'. Its a PITA to remove the lines on a 02+ GT. Takes longer then 10minutes like everyone has told me.
Just one quick question, if i installed my fuel filter in the wrong flow direction, would i have noticed it right away after driving it? or would it still drive fine? and also, when putting on the new filter and reconnecting the lines, did u just reconnect the lines by hand and pop them on, is that tight enough? i did that, i hope it doesnt leak?
Calizic
08-28-2015 01:46 PM
