Speed release or Triple hook???
Old 12-20-2007, 09:25 PM
brent_cosenza
brent_cosenza's Avatar
Default Speed release or Triple hook???
which is better the speed release from UPR or the UPR Triple hook and does it completely eliminate the plastic gearing that holds the cable and if so how does the aftermarket one grip the clutch cable with no teeth wouldnt it slip?
brent_cosenza is offline
Old 12-21-2007, 03:45 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Default RE: Speed release or Triple hook???
The "teeth" have nothing to do with holding the cable, they are entirely related to the ratcheted adjustment mechanism. All of the plastic stuff (including the OEM adjuster) is removed and the new quadrant is mounted to both fixed pins on the pedal--the OEM quadrant pin and the ratchet pin. The "hooks", one on the speed release and 3 on the triple-hook, hold the cable end.[/align][/align]The UPR speed release quadrant requires an adjustable cable and optionally a firewall adjuster, the triple-hook quadrant requires a firewall adjuster (I have the 3-hook and UPRs Quick-click adjuster), and will work with the OEM cable. I have read a number of tales of aftermarket clutch cables being of lesser quality, don't know if this is true however my car is my DD and I don't need that sort of problem cropping up 200 miles from home.[/align]
cliffyk is offline
Old 12-21-2007, 07:55 PM
JayC
JayC's Avatar
I happen to have both. I use a UPR speed release with a stock cable. Much better for shifting at the track but the triple is nicer for the street. [8D]
JayC is offline
Old 12-21-2007, 08:51 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
ORIGINAL: JayC
[/align][/align]UPR told me the quick release wouldn't work the the OEM cable--wouldn't be the first time a sales person was wrong though...[/align]
cliffyk is offline
Old 12-21-2007, 10:16 PM
jmac72187
corner carver
jmac72187's Avatar
ORIGINAL: cliffyk
ORIGINAL: JayC
I have the Steeda quick release on my old GT with the stock cable. I am not sure whether the steeda and UPR are the same though.
jmac72187 is offline
Old 12-21-2007, 11:00 PM
lizzyfan
Underboss
lizzyfan's Avatar
ORIGINAL: jmac72187
ORIGINAL: cliffyk
ORIGINAL: JayC
A bud has a UPR and say's it rattles! I have a quick release from Steeda getting readyto put on and was told I need to use a firewall adjuster also. Is this true?
lizzyfan is offline
Old 12-21-2007, 11:14 PM
defconfire
defconfire's Avatar
ORIGINAL: lizzyfan
ORIGINAL: jmac72187
ORIGINAL: cliffyk
ORIGINAL: JayC
You dont NEED it if you replace the clutch cable with an adjustable one, but it is HIGHLY RECCOMENDED, it makes life a lot easier.
defconfire is offline
Old 12-22-2007, 09:07 AM
JayC
JayC's Avatar
I would go with the firewall adjuster. The UPR is a Steeda clone......if it's rattling it's not adjusted right[8D]
JayC is offline
Old 12-22-2007, 10:30 AM
lizzyfan
Underboss
lizzyfan's Avatar
ORIGINAL: JayC
It's perfectly adjusted
lizzyfan is offline
Old 12-22-2007, 12:15 PM
JayC
JayC's Avatar
ORIGINAL: lizzyfan
ORIGINAL: JayC
Use washers on the pivot points?
JayC is offline
Quick Reply: Speed release or Triple hook???
