Mustang Performance Packs
RE: Mustang Performance Packs
here are some idea's for what to get if you are putting new gears in.
http://www.jegs.com/webapp/wcs/store...63016_-1_10667
ORIGINAL: Aereon
Bolt in's are useless as they require drilling into the chassis and that just makes the chassis weaker.. Cold air intakes gains are really debatable, if your looking for similar gains, remove the snorkel from your stock air box.
I would say a tb/plenum does nothing as he does not have enough airflow to max out the stock one, in stock form that is. K&N is a good and readily available filter but whenever you change your filter just make sure you spray your maf down with maf cleaner, as k&n's tend to leak oil. pullies lower rotational mass thus increasing fuel mileage + free's up a few horses but if your gonna supercharge later on your going to need to replace the u/d pully with the stock one, keep this in mind.
squishbang
Suspension
11-02-2015 03:42 PM
Daleford
08-10-2015 08:30 PM
