whats wrong with my car? Hesitating
Ok so i noticed this problem a few weeks ago, but ignored it since it only happend when it was really cold outside, and the engine was cold as well. It would stop as soon as my temp gadge got right dead center (when the engine was warm)
However, driving home from work tonight (and after the engine has had plenty of time to warm up) I start to get the sputters again. Let me see if I can try to explain whats happening:
r is normal engine sound accelerating
s is when it sputters
1st gear
rrrrrSSrrrrrSSrrrrrrrrrrrrrrSSSrrrrrrrrrrrrrrrrrrS SSrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
2nd gear
rrrrrrrrrrrrrrrrrSSSSrrrrSSrrrrrrSSSSSSrrrrrrrSSSS SSrrSSrrSSrrSSrrrrrrrrrrr
3rd
rrrrrrrrrrrrrrrrrrrrrrrrSSrrrrrrrrrrrrrrrrrrrrrrrr rrSSSrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
(keep in mind im "getting on" the gas too, and I can feel the sputters in my acceleration, its an obvious loss of power)
I cant pinpoint whats going on. however, I can say that my exaust has been strangly louder recentally (I dont know if that could have anything to do with it). Also, when it sputters, It backfires alot of the times.
Any ideas about what could be goind on? Back pressure problem? I looked under the car and couldnt hear/see/smell any exaust leaks, although I could be wrong. Im open for ideas. I work at Tire Kingdom so I have access to ramps and ****. I can get whatever info u need (with some time)
I have magnaflow catback w/ o/r mac h pipe
1st gear
2nd gear
3rd
RE: whats wrong with my car? Hesitating
this is a very common problem with our cars. its one of a few things, you could start by changing the fuel filter, if not that its prob the throttle position sensor, or lastly a fuel pump.
I had a 73 Mach 1 with the 351 Cleveland and it did that for awhile. Couldn't figure it out. A friend of mine(mechanic) put in a new distributor and new ignition in and it stopped. =/
+1.. Especially the TPS.
ORIGINAL: lewistk
well I know its not the fuel filter, As I just replaced it maby 1k miles ago... throttle position sensor? how do I check if that is ok or not? And my fuel pump that would suck. How do you check if these things are bad or not?
I have been chasing the same problem with my 2002 GT (except it does not backfire) and have not figured it out yet. Mine is worse when the engine is up to temperature. I've been told to try a bunch of things, by different people. So far I've:
Cleaned the throttle body
Cleaned the MAFS
Cleaned the IAC
Cleaned the EGR
Had a BG fuel injection cleaning service done
changed the fuel filter
Changed the spark plugs
Put a new boot kit on the coils
None of this helped at all. It would be better for about 20-30 miles then go back to the same thing.
I was going to get the Accel COP kit as my next step (less $ than 8 stock coils), but I will try the TPS first since it costs less.
Note: My GT has 110,000 miles on it.
Cleaned the MAFS
Cleaned the IAC
Cleaned the EGR
I guess I will change the TPS as well. Can somebody tell me where I can pick this up from? I was going to go with "a bad spark plug" but it didnt seem to help the above person.
on a side note, how do you know if you do have a bad spark plug? I sware that COULD be my issue... however I will not know till I replace them.
where can I get hte TPS? At autozone? advance? napa?
Any one of the stores that you listed should have it...
Here it is on AutoZone's web site:
http://www.autozone.com/N,15900136//...eResultSet.htm
Yeah it can be had for like 30 bucks. And for the guy above with the list. Change the TPS also it is a 10 minute job. It is so very common...
ORIGINAL: swooshonln
havent really looked around yet but where is the TPS located at under the hood? and im guessing if my car would be cruising at 40mph and all a sudden for a half second it feels likei let go of the gas but then it was fine again it would also be this problem?
