Backpressure
RE: Backpressure
from what ive heard is that you want your exhaust gases free flowing as possible and as little back pressure as possible. where did you here that if you remove yours cats it will destroy your valves?
RE: Backpressure
ORIGINAL: tylerl90
Ok I've heard different things about backpressure on an engine. But I always thought it was bad to have backpressure.
If I have my cats removed, will it "destroy my valves?"
you want AS LITTLE BACKPRESSURE AS POSSIBLE
RE: Backpressure
Ok For anyone who want to know back pressure is bad! The minimum back pressure is almost always optimal, BUT to achieve minimal back pressure can mean using a smaller pipe because of the scavenging effect, which actually helps to further reduce back pressure. You have to find a happy balance
*edit: and you wont cook your valves going catless.
RE: Backpressure
MM&FF did a test on this. No backpressure at all made the least amount of power. All of the mufflers they tried were within 1 hp of each other but the car lost like 3 hp from stock with no mufflers at all. 1 or 3 hp, who cares, I think everyone just needs to put what they think sounds the best on there cars.
