cracked head?
RE: cracked head?
ok well.... Im going to go ahead and say my car.... isnt.... smoking
I hope its a gasket if anything though... I work at a shop so Im not too worried about install... just a gasket is alot cheaper than a head haha.
I have the aluminum intake manifold.
so far it hasnt filled back up.
RE: cracked head?
ORIGINAL: MineralGrey
correct me if I'm wrong but I'm pretty sure, unless it has something to do what color your anti-freeze is.
ORIGINAL: 2002GTAUTOVERT
green smoke for a cracked block?
In 20+ years I have never heard of or seen green smoke..... LOL!! It's either white, blue, or black.
Lynn
RE: cracked head?
ORIGINAL: swooshonln
damn, whats a sure way to tell if your head is cracked or not? If it is a head gasket are there any "stop-leak" substances to put in your radiator to fix it?
RE: cracked head?
ORIGINAL: fyouceeku
Pressure check the cooling system cold and see where you get a coolant leak from. Stop leaks are at best a band-aid over a gunshot wound IMO.
RE: cracked head?
ORIGINAL: LynnBob Mustang
White smoke will come from a cracked block or head gasket, it is the steam or vapor created by coolant/water mix leaking into where it shouldn't wether it be from a cracked block into the cylinder or by a head gasket.
Lynn
Lynn
RE: cracked head?
well.... Ill ask this. how clear "SHOULD" my exaust be? (no leaks/nothin)
I have no cats and catback exaust... I do "see" white smoke... but only when its cold out. I assume thats normal though?
