cracked head?
Old 12-27-2007, 11:50 PM
swooshonln
swooshonln's Avatar
Default cracked head?
I took my coil over off the spark plug that was causing my misfire, and it was filled with what smelled like coolant. do I have a cracked head? maby just a bad gasket? what do you think?
swooshonln is offline
Old 12-28-2007, 12:13 AM
Whamo
Whamo's Avatar
Default RE: cracked head?
sounds like a blown headgasket to me
but could be a cracked head aswell either way the gasket has to go so might as well plan to change the gasket but check the head.
or if your talking about under just the plug cover then it may be a leak elswhere and the coolant pooled there. drained your coolant lately?
Whamo is offline
Old 12-28-2007, 07:31 AM
swooshonln
swooshonln's Avatar
no I havent drained it before. Should I?
Old 12-28-2007, 07:38 AM
1fstblckgt
I ♥ Acer
1fstblckgt's Avatar
Do you have the aluminum crossover on your intake manifold?
1fstblckgt is offline
Old 12-28-2007, 11:34 AM
MineralGrey
MineralGrey's Avatar
For a future reference
Blown Head = Thick White Smoke
Cracked Block = Green Smoke
Fried Piston Rings = Blue Smoke
I highly doubt its cracked just check for a leak somewhere, I noticed the coilpacks on our cars don't do a very good job of keeping crap out of the chambers, atleast on my vehicle.
MineralGrey is offline
Old 12-28-2007, 01:50 PM
2002GTAUTOVERT
2002GTAUTOVERT's Avatar
ORIGINAL: MineralGrey
[align=left]For a future reference[/align][align=left][/align][align=left]Blown Head = Thick White Smoke[/align][align=left]Cracked Block = Green Smoke[/align][align=left]Fried Piston Rings = Blue Smoke[/align][align=left][/align][align=left]I highly doubt its cracked just check for a leak somewhere, I noticed the coilpacks on our cars don't do a very good job of keeping crap out of the chambers, atleast on my vehicle.[/align]
green smoke for a cracked block?
2002GTAUTOVERT is offline
Old 12-28-2007, 02:05 PM
Sxynerd
Sxynerd's Avatar
I'd say HG.
Sxynerd is offline
Old 12-28-2007, 03:28 PM
MineralGrey
ORIGINAL: 2002GTAUTOVERT
correct me if I'm wrong but I'm pretty sure, unless it has something to do what color your anti-freeze is.
Old 12-28-2007, 04:16 PM
lewistk
lewistk's Avatar
+1, headgasket
lewistk is offline
Old 12-28-2007, 04:52 PM
tylerl90
tylerl90's Avatar
Yeah if your car has any of those 3 symptoms, it's safe to assume you're royally f**ked.
tylerl90 is offline
Quick Reply: cracked head?
