Best way to launch
Old 11-12-2003, 04:00 PM
  #21
SilverGTV8
SilverGTV8's Avatar
Default Best way to launch
1st time at the track with the car. My best run was my first run, 14.4. I know i can pull a 14.1. I had a couple of 2.0 60s which is awsome on street tires for the car, but lost it all down track. Mildly modded 4.6 99-td stangs were running 14.1s that nite. The temp went south fast and screwed the track up royally. By my 4th run pulling third step the car out. 60fts weren't bad, 2.1's the 4th and 5th runs I did but lost it all down track with dropped temps.
SilverGTV8 is offline
Old 11-18-2003, 01:28 PM
  #22
tony
tony's Avatar
hey newbie here I ran a 14.3 @ 100.1 mph with 24 psi in the street tires and 1.00 reaction time . I need help to get it down to 13.9 or 14.0 . I am looking at getting new gears, I have 3.27's how are the 4.10's how much faster should it put me .
tony is offline
Old 11-19-2003, 08:24 AM
  #23
SilverGTV8
SilverGTV8's Avatar
A stock 03 GT coupe is capable of running 13.9 with a little help. less than 1/4 tank of gas, no spare, no FGS, less tire pressure, and a killer 60 ft time.</P>
This doesn't happen often but you can do it with your existing set-up.</P>
4.10's should help. I am torn on whether to get 4.11's or 3.73's. Just can't make up my mind. I don't really want to lose a lot of top end.</P>
Old 11-20-2003, 12:50 AM
  #24
tony
tony's Avatar
I am still learning the lingo what do you mean ( FGS )
tony is offline
Old 07-06-2004, 05:21 PM
  #25
jishead
jishead's Avatar
Default RE: Best way to launch
Ever figure out what FGS is?
jishead is offline
Old 07-07-2004, 08:24 PM
  #26
GT03
GT03's Avatar
I'm too trying to get a 13 with my gt. I've gotten down to 14.2 by feathering the clutch at 2700 and then powershifting into second. This does cause the car to spin but it has gotten me my best time. I think next up grade is tires.
Joe
GT03 is offline
Old 07-07-2004, 09:48 PM
  #27
stonemonk9
stonemonk9's Avatar
someone please explain how u "feather" the clutch? is that to let it out more slowly than droping it? and also how wuld u power shift second? if u get the rpms around 5k and pull into second, it will jus go in?
stonemonk9 is offline
ctgreddy
10-14-2015 09:05 PM
TCStangerv6
10-11-2015 05:57 PM
10-07-2015 07:02 PM
Daddys Girls GTs
09-14-2015 08:46 PM
vintageaion
09-08-2015 10:45 AM
Quick Reply: Best way to launch
