times?
Old 01-15-2008, 03:34 PM
0526gt
0526gt's Avatar
Default times?
Hi i have a 2002 mustang gt coupe. i have installed a pp upper intake throttle body and lower intake, a k&n cold air intake, mac off road prochamber x-pipe and an slp lm1 cat back, i have also installed a pro-5.0 shifter, along with a centerforce dual friction clutch. I am planning on taking it to the strip this spring and wanted to know what times i should be expecting in the 1/4 mile.
thanks,
garrett
0526gt is offline
Old 01-15-2008, 03:53 PM
SXGT
SXGT's Avatar
Default RE: times?
ORIGINAL: 0526gt
thanks,
garrett
I will assume youre a perfect driver under perfect conditions and then post times for alt conditions.
2002 GT - --------------------------------14.1 ET at sub 500ft elevation and 56 degree weather or less
pp upper intake throttle body------------- -0.2
lower intake--------------------------------- -0.1
k&n cold air intake ------------------------ -0.1
mac off road prochamber x-pipe---------- -0.2
slp lm1 cat back --------------------------- -0.2
pro-5.0 shifter ------------------------------- -0.1
centerforce dual friction clutch ------------ -0.1
total = -0.9
you might run a 13.2 at sub 500ft elevation and 56 degree weather or less.
driver ability is about +/- 0.3
SXGT is offline
Old 01-16-2008, 08:09 AM
OV10stang
OV10stang's Avatar
Default RE: times?
High 13's.
OV10stang is offline
Old 01-16-2008, 01:50 PM
JayDs Ibanez
JayDs Ibanez's Avatar
Default RE: times?
yup, high 13s
JayDs Ibanez is offline
Old 01-16-2008, 01:53 PM
03mustgt
03mustgt's Avatar
Default RE: times?
ORIGINAL: JayDs Ibanez
yup, high 13s
+1, high 13s if you can drive, but dont be surprised if you see some 14s.
03mustgt is offline
mungodrums
10-07-2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
09-28-2015 09:18 PM
StalkerGT
09-25-2015 02:41 PM
09-08-2015 11:50 AM
Quick Reply: times?
