2002 GT starting problem
Old 01-17-2008, 04:21 PM
Aragorn
Aragorn's Avatar
Default 2002 GT starting problem
Hi guys. I have a 2002 GT that will not start. It clicks repeatedly, but does not turn over. Initially, I thought battery but could not get it to jump.
That would lead me to believe starter. Is there any way to be sure of the problem? I don't have a code reader, nor do I know anyone with one. What do you all think? Thanks so much.
Aragorn is offline
Old 01-17-2008, 04:23 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Default RE: 2002 GT starting problem
Take the battery and starter out, take them to your local autozone. They'll test both.
Derf00 is offline
Old 01-17-2008, 04:30 PM
Aragorn
Aragorn's Avatar
Is pulling the starter going to be tough? It's cake on my lifted pickup, but on a mustang?
Aragorn is offline
Old 01-17-2008, 06:11 PM
bluepony4.6
bluepony4.6's Avatar
ORIGINAL: Aragorn
Oh yeah it will pretty tough friend. Bring a lunch.
bluepony4.6 is offline
Old 01-17-2008, 09:30 PM
Aragorn
Aragorn's Avatar
Ok, but is there even the possibility that it could still be the battery even though it will not jump? It's the original battery on an 02. Then again, it's the original starter on an 02.
Aragorn is offline
Old 01-17-2008, 09:59 PM
fruhdaddy
fruhdaddy's Avatar
its most likey your starter..Have your battery tested first by like autozone or somebody if its good then it could be your starter..also check your battery connections. Your starter is a 3 bolt design. Its not really hard but is a pain. Best thing is to take off passenger wheel and put jack stands underneath to access better
fruhdaddy is offline
Old 01-22-2008, 09:12 PM
Aragorn
Aragorn's Avatar
Alright guys, thanks for the input. I had the battery tested and it was declared dead. Bought a new one and it cranked right up. Why it wouldn't jump remains a mystery. Thanks again for everything!
Aragorn is offline
Old 01-22-2008, 10:36 PM
doug0122
doug0122's Avatar
i had the same issue...you should have been able to tell as my battery began to die my starter truned sluggish...after the new yellow top i put in it cranked over great
doug0122 is offline
Old 01-23-2008, 02:29 PM
Mitch02GT
Mitch02GT's Avatar
I had the same thing happen last spring when I took the car out. The battery was completely drained and all it did was click when we tried to fire it up. We just charged it and it was as good as new!!!
Mitch
Mitch02GT is offline
Gary Ugarek
09-05-2015 09:03 PM
Stilz
08-18-2015 09:40 AM
jjwinel78
08-17-2015 03:34 PM
KEM Motorworks
08-14-2015 10:13 PM
Pain.
08-07-2015 10:48 PM
Quick Reply: 2002 GT starting problem
