V6-V8 conversion
Old 10-05-2003, 02:15 AM
85vert
85vert's Avatar
Default V6-V8 conversion
Hey guys</P>
im coverting my 3.8l v6 tbi -to a 302 carb set up. I prefer a carb setup over the efi. i need to know what i need to change about the fuel system. </P>
anybody have some spare time drop me a email</P>
thanks<IMG src=smileys/smiley10.gif border="0"></P>
</P>
</P>
85vert is offline
Old 10-05-2003, 02:29 AM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
I'll spare ya some time and say it for you:</P>
He's looking for a fuel system upgrade, not opinions about why V6/V8 swaps aren't worth it. <IMG src=smileys/smiley2.gif border="0"></P>
Dan04COBRA is offline
Old 10-05-2003, 03:13 PM
USAMuscle
USAMuscle's Avatar
lol, good call
USAMuscle is offline
Old 10-05-2003, 07:44 PM
BCisme
BCisme's Avatar
besides the obvious bigger carb, wich will prob rquire you to make some adjustments to your fuel lines,your gonna need a bigger pump i'd imagine, prob more stuff too.
BCisme is offline
Old 10-05-2003, 08:44 PM
InMyRearView
InMyRearView's Avatar
Fuel accomodation will NOT a problem if you,re running a carb. You may even be able to use your existing fuel pump with the addition of a relay and a fuel pressure regulator or perhaps a universal fuel pump. If thats not practical, run a mechanical pump and do away with all the relay stuff but you'll have to drop the tank and set up your fuel delivery for a mechanical pump.IMO I think your existing pump with a regulator and relay(to control when its on and off) will do the trick. Cut your metal fuel line at some point under the hood where you can run fuel hose to the carb. I may have left out a few details but I think you'll get the picture of what needs to be done.Fuel pressure on a carb is lower than fuel injection .
InMyRearView is offline
Old 10-06-2003, 12:37 AM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
don't know how long that stock pump is gonna lastregulated down to 6 - 8 psi, not to mention stock pumps are high pressure, low volume. Best thing to do is swap in a tank from a carb'd mustang or modify your tank for an external holley pump or something. </P>
</P>
mdvaldosta is offline
Old 10-06-2003, 01:33 PM
InMyRearView
You should be o.k. up to 300hp using stock pump with a returm fuel regulator. Above that you'll have to trash the factory pump and do as mdvaldosta mentioned adding a pick- up line in your tank(thats the modification he's talking about) and do a mallory or holley electrical with a regulator. Something to that effect. do Its really going to depend a lot on how much power you're going to produce and if your current fuel system is return or returnless. The main thing to remember is that if you dont use your stock pump, put a pick up line in the tank. They make a pick-up line kit for $70-$85.
Old 10-06-2003, 02:08 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
yea I agree
Undefinedghost
05-08-2013 07:49 AM
obxdude018
03-25-2013 06:25 PM
Fordatheart1996
12-05-2011 11:53 PM
ctgreddy
03-13-2010 10:28 PM
scottmcg86
11-30-2007 10:59 PM
Quick Reply: V6-V8 conversion
