New Plenum and Rev Limiter
Last Saturday, I installed a 75mm plenum. Since the computer has time to adjust, the limiter is now kicking in around 6300-6400 where as before it would activate just past 6000.
Is this change bad for the motor because I also want to uprade to a 75mm TB?
RE: New Plenum and Rev Limiter
That should have nothing to do with the rev limitor. The rev is all done by computer and not air/fuel leanness! Also, you should have no need to go above 5300rpms with a 2v motor. They start losing power after that! 5500rpms shifting max, but you shouldn't hit 6k ever!
treesloth
09-28-2015 07:03 AM
