2V Engine codes
RE: 2V Engine codes
what are the short and long trims at? the 1131 and 1151 are generic lean codes and you will usually fint the trims adding fuel at idle or off idle if the trims go over 10% you can set p0171/p0174 or these codes
RE: 2V Engine codes
Not too sure if im quite following you too well dandy but i, I noticed after i cleared the codes if i had the car idling for a few mins then the light would come on...
RE: 2V Engine codes
ORIGINAL: craigwhite89gt
P0135 Heated O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
P0155 Heated O2 Sensor Heater Circuit Malfunction (Bank 2, Sensor 1)
P1131 Lack Of HO2S11 Switch - Sensor Indicates Lean
P1151 Lack Of HO2S21 Switch - Sensor Indicates Lean
Any one had these?
Any one had these?
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
zanemoseley
09-06-2015 12:58 PM
