Stuck Caliper
Stuck Caliper
I have another stuck caliper. This time on my driver's side rear. The inside pad is stuck to the rotor and the outside pad doesn't even touch the rotor when the brake is pressed. I heard someone say that I might just need a caliper rebuild kit. Is it hard to rebuild the caliper instead of just buying a new one?
RE: Stuck Caliper
OMG I can't believe this happened to someone else. Mine slowly stuck so it worked it's way through the disc, ugly, really ugly. To fix it we had to replace the back half of the caliper bracket, at that point just get a new caliper. Must be a Ford thing.
RE: Stuck Caliper
its not a ford problem , its a lack of maintenance . you should grease the slider pins/rods every year , front & rear . I've seen them stuck so bad you cant get them out w/ a vise , hammer & plyers .
RE: Stuck Caliper
I had the same thing happen to me 3 months ago. lol It was bad. My rear passenger caliper decided to lock up in the middle of town. Talk about one of the most horrendous sounds...
I ended up having to buy a whole new caliper. It wasn't that expensive though.
RE: Stuck Caliper
Typically, lack of grease on your pins will cause this, or a rip/tear in the boot to allow sediment to the sliding pins.However, it could be the square rubber ring around the piston. If that goes bad, it will also keep your caliper from retracting. You could get a new one, but rebuilding themiseasy. The hard part is finding a parts store that will sell you a seal kit. They should be less than $10 plus some brake fluid.
RE: Stuck Caliper
It's not a Ford thing. Brakes wear out. I've replaced pads, calipers and rotors (drums) on almost every GM, Ford and Chrysler car I've owned.I tend to keep cars a long time. I suppose you could keep a caliper from locking up by taking it off and greasing the pins every year, but I don't know anyone who does that. Most people only do that when the car needs pads.
Buy a rebuilt caliper at Autozone. Don't forget to take back your old caliper to get a refund. You will need to put new pads on both sides of the car when you replace it. Be sure to lub the pins on the good caliper.
RE: Stuck Caliper
Thanks guys. Well luckily I am in brakes class now at school and my teacher looked at it and said the same thing as you guys. It was because of the slider pins. It took a good amount of effort to get them out of the bracket. I called 3 part stores and they didn't have the pins so I called 3 Ford dealerships and they said it was special order and the earliest I could get the pins was in 3-5 buisness days. Finally I found a Car Quest that had them. Brakes work great now but my brake light comes on when I hit the brakes. I'll have to have my teacher take a look at it.
