Speedo Fix After Gear Install...
Old 03-01-2008, 12:47 AM
06z28eater
06z28eater's Avatar
Default Speedo Fix After Gear Install...
The 96 GT I got for my girl a few weeks ago had gears installed a few months ago and the guy never fixed the speedo, In my 03 I put the SpeedCal in, but someone said you cant do that unless it's 99-04 but I'm not sure about that, my buddy has a little plastic gear or something he said he installed, any info about what I should do to fix this would be great, it's a 96 Automatic GT.
06z28eater is offline
Old 03-01-2008, 11:01 AM
99gt302
99gt302's Avatar
Default RE: Speedo Fix After Gear Install...
nvm, dunno bout an auto...
99gt302 is offline
Old 03-01-2008, 12:38 PM
06z28eater
06z28eater's Avatar
i looked on ebay for the little speedo gear, but cant really find what i think i need, anyone??
Old 03-01-2008, 03:01 PM
johndeeregreen
johndeeregreen's Avatar
the speed cal will work on the 03 but for the 96 if the tranny is the t45 then you need the plasic gear change there are palces that sell them they arn't that exspensive
johndeeregreen is offline
Old 03-01-2008, 03:24 PM
Pauly_B
Pauly_B's Avatar
Get a Diablo Handheld, you can change the gear ratio setting to whatever the gears u had installed. it will fix your speedo and the shift points will be at the right position for your gear set up. they are expensive but it will be well worth it
Pauly_B is offline
Old 03-01-2008, 03:46 PM
96GT226410
CSMG Moderator
96GT226410's Avatar
You need to use a SpeedCal or buy the plastic gear. The plastic gear is more involved to install, but a lot cheaper. I'd go with the SpeedCal.
96GT226410 is offline
Old 03-01-2008, 05:40 PM
Injected97GT
Injected97GT's Avatar
ORIGINAL: Pauly_B
NO IT WILL NOT. A Diablo or SCT handheld is great to have, and can do a lot for you. but on a 98 or older SN95, it will NOT change your speedo for gears or tire size. You NEED either the plastic gear or the SpeedCal.
Again, as I have learned on my 97, your handheld tuner WILL NOT correct your speedy on a 96.
Injected97GT is offline
Old 03-02-2008, 12:33 AM
06z28eater
06z28eater's Avatar
i was searching and seen a old topic today where they said the tuner would NOT fix the speedo prob, but can you get a speedcal? when i put mine in my 03 i believe all i could find where 99-04 5 speeds, can someone find me a place? or maybe i can google it when i get home and find 1, and does anyone know how hard it is to install the speedo gear? the little gears i seen on ebay were only like 15 bucks or so.
Old 03-02-2008, 04:00 PM
Injected97GT
http://www.americanmuscle.com/speed-...tor-94-04.htmlthere you go. problem solved
Old 03-03-2008, 12:33 AM
06z28eater
06z28eater's Avatar
thanks man! didnt even check there, and thats where i got mine for my 03 at haha, i see how the plastic piece is ALOT cheaper, but it isnt worth it is it? b/c it isnt 100% accurate even after putting the litle gear in, is this correct or did i misread this while searching??
Quick Reply: Speedo Fix After Gear Install...
