speedometer
Old 03-01-2008, 09:22 AM
jtfrog
jtfrog's Avatar
Default speedometer
The previous owner installed white face guages and now the speedometer is off by 5 mph. Can I change the plastic speedo gear in the tranny to fix this?
jtfrog is offline
Old 03-01-2008, 10:50 AM
HEAVYMETALMATT
HEAVYMETALMATT's Avatar
Default RE: speedometer
i have the same issue man, but mine is off by 7. and no you cant change the gear, cuz then youd be way off at higher speeds. its the needle itself that off, not the speedo gears.
HEAVYMETALMATT is offline
Old 03-03-2008, 12:02 PM
jtfrog
jtfrog's Avatar
My next option is to have it recalibrate but I cant find anyone local that can do this. Where is the the best place to have this done?
jtfrog is offline
Old 03-03-2008, 02:16 PM
Natex
Natex's Avatar
I've installed plenty of whiteface kits... you need to pull the need out with a small prying device then with the cluster hookedinto the terminal -turn the key on so all the lights are on inthe cluster - then while pointed at zero,very gently push the needle back into place. Most people push in the needle while the key is off which throws off the calibration.
Natex is offline
articman
06-21-2018 11:45 PM
Mr. D
Wheels & Tires
15
08-22-2015 02:58 PM
Nurdyguy
08-21-2015 10:23 PM
danclint
11-28-2004 10:32 PM
Leadfoot
09-10-2004 03:05 PM
Quick Reply: speedometer
