help me!
Old 03-01-2008, 10:36 AM
modularmadman
modularmadman's Avatar
Default help me!
i went to start my 1998 GT this morning, to make sure its not sitting without running for a while, cuz my dad drives the mach1 to work
and it didnt even start to turn over, and the power door locks dont work either, or the horn, or even the radio
and its not the battery, we just got one about 9 months ago, and the only time the battery is in use, is when i start the car, i dont listen to the radio when parked
anyone have any ideas?
modularmadman is offline
Old 03-01-2008, 10:49 AM
Mark99GT
Mark99GT's Avatar
Default RE: help me!
Sounds like the battery to me. Did you test it? When did you start it last? Did you try to jump it? Did you make any recent modifications or add stereo equipment?
Mark99GT is offline
Old 03-01-2008, 10:56 AM
black35th
black35th's Avatar
Did you check to make sure your battery cables were connected? Maybe your dad unhooked the negative?
black35th is offline
Old 03-01-2008, 11:31 AM
modularmadman
everythings connected, and we have done no modifications to the stereo, and the battery is still good, we're gunna try to jump it when he comes home from work
the last time i started it up was like 2 days ago at MOST
and the battery warning wasnt even on
Old 03-01-2008, 01:02 PM
baino
baino's Avatar
Maybewhen youjump it, check little things like your dome light and what not to see if it was left on.
baino is offline
Old 03-01-2008, 02:15 PM
Obsequious1
Obsequious1's Avatar
I had that happen to the battery in my old neon once. I put the charger on it and it said it was fully charged. I think it was a bad load cell or something. Then I had another problem with a new battery I had in my exploder. The pos terminal must have been broke inside the battery because you'd have to push down on the pos terminal to get any juice. luckily I still had a warrantee on it. Put a charged battery in it, if it starts well thats your problem.
Obsequious1 is offline
Old 03-05-2008, 05:28 AM
modularmadman
problem solved it was parasitic drain in the a/c
just a small short, we replaced the fuse, nothing to worry about
thanks for input tho!
