SCT Two step rev limiter help please
I setup my SF3/X3 tuner in my 2000 GT 5spd Convertible with a built in strategy flash for a 2500rpm neutral rev limit which gave me a sweet launch but...... Whilst driving my rev limit only goes to 2500rpm! Not so great! I checked my tune settings to make sure that the driving rev limit hadnt changed and it was set at 6500rpm so that was correct. I then reflashed the comp and still it limited to 2500rpm!
I gave up and flashed the neutral limit to 6500 to make the car drivable but i would really like the two step to work correctly.
Did I miss something in the setup? Is there something wrong with my car? (Clutch start inhibit works) MIght there be something wrong with the tuner?
RE: SCT Two step rev limiter help please
The tuner has to go into the handheld and change one of the parameters to .5 instead of 1 for it to be enabled. Otherwise it just works as a one-step. I tried to do this same thing on my car, couldn't get it to work. I took my car to mph and he said it won't work at all on a 96-98 computer without an msd ignition setup.
Location: Where gunshots are more common than birds chirping
If you're a manual your car will think you're in neutral all the time therefore limiting you all the time. Drive rev limit is for auto's.
ORIGINAL: 35thAnni99GT
I would do what the above poster said, check with your tuner to see if it needs enabled. I know alot of people have had trouble with the SCT xcal rev limiter for some reason.
ORIGINAL: 2000GT4.6
The first rev limit is set to zero speed, not for the car being in maual. It will work on a manual... thats the entire point.
Could i check to see if is enabled?
ORIGINAL: 2000GT4.6
I got mine and it did just as the OP described. I told my tuner what was going on, and he emailed me a tune that had the 2 step in it, and it did the same thing. So I just figured it didn't work with a 5spd, but EVERYONE says they think it will. So I just called them up. That's not the case.
Matt's 95 Stang
10-05-2015 07:16 AM
treesloth
09-28-2015 07:03 AM
09-25-2015 06:58 PM
