HELP ASAP!!!!!!!!!!!!
i'm ordering all of my gaskets for my rubuild right now, and i'm not sure which head gaskets i need to get. not sure of the bore and compressed thickness! it's a 302 stroker, i didn't have the cylinders bored, just honed, and i have no clue what compressed thickness i need! i'm running patriot performance stage II heads, if that helps. and 10:1 compression ratio. please help asap so i can get these ordered!! thanx!!
RE: HELP ASAP!!!!!!!!!!!!
Order the stock head gaskets from Ford. They are exactly what you need. Triple layer metal gaskets. I've talked to several shops that build these motors when I was building mine and they all said the best gaskets you can get are the OE gaskets.
