wat about the track heat? thats the one i was considering going w/.
I highly recommend the track heat. It has had the best reviews of any aftermarket manifold on the market right now. I'm running it and love it. Its a pretty easy install which is almost a direct replacement. There is only two modifications required, extending IAC harness (2 wires), and modifying the EGR tube. If you are good with wrenches, then it shouldn't be an issue. It comes with very good step by step instructions and is a very complete kit with everything you need for the install.
